DebugFail Method (String, String) |
An error message, with detailed error information and a stack trace, is displayed on the FlexPendant.
The error message, with detailed error information and a stack trace, is also sent out on the network.
The error message can be displayed in the controller console by enabling the functionality
on the controller. Use fpcmd_enable_console_output to enable FlexPendant logging.
Namespace:
ABB.Robotics.Diagnostics
Assembly:
ABB.Robotics (in ABB.Robotics.dll) Version: 6.5.129.0
Syntaxpublic static void Fail(
string message,
string detailedmessage
Parameters
- message
- Type: SystemString
A message to write. - detailedmessage
A detailed message to display.
ExamplesThis example displays and logs an error message.
Debug.Fail("Operation not allowed in current state", string.Format("state: {0}", myobj.State.ToString()));
See Also
