Click or drag to resize
DebugAssert Method (Boolean, String, String)
Checks for a condition and displays an assert message on the FlexPendant, with detailed information and a stack trace, if the condition is false. When the condition is false, the message, with detailed information and a stack trace, is also sent out on the network. The message can be displayed in the controller console by enabling the functionality on the controller. Use fpcmd_enable_console_output to enable FlexPendant logging.
Namespace:  ABB.Robotics.Diagnostics
Assembly:  ABB.Robotics (in ABB.Robotics.dll) Version: 6.5.129.0
Syntax
C#
public static void Assert(
	bool condition,
	string message,
	string detailedmessage
Parameters
condition
Type: SystemBoolean
true to prevent a message being displayed; otherwise, false.
message
Type: SystemString
A message to write.
detailedmessage
Type: SystemString
A detailed message to display.
Examples
This example displays and logs an error message if the condition is not fulfilled.
Debug.Assert(myobj.State==RUNNING, "Operation not allowed in current state", string.Format("state: {0}", myobj.State.ToString()));
See Also
