Click or drag to resize
DebugAssert Method
Overload List
  NameDescription
Public methodStatic memberCode exampleAssert(Boolean)
Checks for a condition and displays an assert message on the FlexPendant, containing a stack trace, if the condition is false. When the condition is false, the assert message, with a stack trace, is also sent out on the network. The message can be displayed in the controller console by enabling the functionality on the controller. Use fpcmd_enable_console_output to enable FlexPendant logging.
Public methodStatic memberCode exampleAssert(Boolean, String)
Checks for a condition and displays an assert message on the FlexPendant, containing a stack trace, if the condition is false. When the condition is false, the message, with a stack trace, is also sent out on the network. The message can be displayed in the controller console by enabling the functionality on the controller. Use fpcmd_enable_console_output to enable FlexPendant logging.
Public methodStatic memberCode exampleAssert(Boolean, String, String)
Checks for a condition and displays an assert message on the FlexPendant, with detailed information and a stack trace, if the condition is false. When the condition is false, the message, with detailed information and a stack trace, is also sent out on the network. The message can be displayed in the controller console by enabling the functionality on the controller. Use fpcmd_enable_console_output to enable FlexPendant logging.
Top
See Also
