Gets the modules defined in the task.
Namespace:
ABB.Robotics.Controllers.RapidDomain
Assembly:
Syntaxpublic Module[] GetModules()
Return Value
Type:
Module An array of
Module objects.
Exceptions
RemarksNOTE:When the returned instance is no longer needed you must call its Dispose method.
Examples The method below counts the number of routines in the task.
private int CountRoutines(Controller c)
int result = 0;
Task[] tasks;
try
tasks = c.Rapid.GetTasks();
Modules modules;
foreach (Task t in tasks)
modules = t.GetModules();
Routines routines;
foreach (Module m in modules)
routines = m.GetRoutines();
result += routines.Lenght;
catch (GeneralException ee)
catch (System.Exception ee)
return result;
See Also
