TaskSaveProgramToFile Method |
Saves the current program at the provided location.
Namespace:
ABB.Robotics.Controllers.RapidDomain
Assembly:
Syntaxpublic void SaveProgramToFile(
string stDirPath
Parameters
- stDirPath
- Type: SystemString
Path to the directory where the program should be saved.
Exceptions
RemarksWhen a program is saved a folder, named as the program, will be created and
in this folder the program file (pgf-file) and the modules of the program will
be stored.
Examples This example sets the name of the program and saves the
program in the home directory of the current system.
private void btnSavePrg_Click(object sender,EventArgs e)
try
myTask.ProgramName = textBox1.Text;
myTask.SaveProgramToFile(stHomePath);
catch (System.Exception ee)
See Also
