Gets or sets a value indicating if the task will start when RAPID execution is started.
Namespace:
ABB.Robotics.Controllers.RapidDomain
Assembly:
Syntaxpublic bool Enabled { get; set; }Property Value
Type:
Booleantrue if task will start with execution, else false.
Exceptions
RemarksGrant UAS_RAPID_RESTART is required to set Enabled state.
ExamplesThis example enables task T_ROB1
using ABB.Robotics.Controllers;
using ABB.Robotics.Controllers.RapidDomain;
public void EnableTRob1()
try
EnableTask("T_ROB1");
catch (System.Exception se)
private void EnableTask(string taskName)
Controller c = null;
Task t = null;
try
c = new Controller();
if(c == null)
t = c.Rapid.GetTask(taskName);
if(t == null)
if (t.Enabled == false)
t.Enabled = true;
finally
if (t != null)
t.Dispose();
t = null;
if (c != null)
c.Dispose();
c = null;
See Also
