ZoneData Properties |
The ZoneData type exposes the following members.
| Name | Description | |
| FineP |
Defines whether the movement is to terminate as a stop point (fine point) or as a
fly-by point.
| pZoneEax |
The zone size (the radius) for external axes. The size is defined as the distance of
the TCP from the programmed point in mm.
| pZoneOri |
The zone size (the radius) for the tool reorientation. The size is defined as the distance
of the TCP from the programmed point in mm.
| pZoneTcp |
The size (the radius) of the TCP zone in mm.
| ZoneLeax |
The zone size for linear external axes in mm.
| ZoneOri |
The zone size for the tool reorientation in degrees. If the robot is holding the work
object, this means an angle of rotation for the work object.
| ZoneReax |
The zone size for rotating external axes in degrees.
