ZoneDatapZoneEax Property |
The zone size (the radius) for external axes. The size is defined as the distance of
the TCP from the programmed point in mm.
Namespace:
ABB.Robotics.Controllers.RapidDomain
Assembly:
ABB.Robotics (in ABB.Robotics.dll) Version: 6.5.129.0
Syntaxpublic float pZoneEax { get; set; }Property Value
Type:
Single
See Also
