Module Methods |
The Module type exposes the following members.
| Name | Description | |
| CreateRapidData(String, String, Scope, StorageType, Int32) |
Creates a new RAPID data in the module according to specified parameters.
| CreateRapidData(String, String, Boolean, StorageType, Int32) |
| CreateRoutine(String, Boolean) |
Creates an empty routine in the module.
| CreateRoutine(String, Boolean, RoutineType, String, ParameterData) |
Creates an empty routine in the module in accordance with specified parameters.
| Delete |
Deletes the RAPID module the Module object refers to from program memory.
| DeleteRapidData(String, String) |
Removes a specified RAPID data instance from the module.
| DeleteRapidData(String, String, Boolean) |
| Dispose |
Disposes the managed resources of the instance.
(Inherited from SDKDisposeBase.) | |
| GetRapidData | Gets a RapidData object that references a RAPID data instance in the robot controller. | |
| GetRoutine |
Gets a Routine object to a specific RAPID routine.
| GetRoutines | Gets the routines defined in the module. | |
| GetText(TextRange) |
Returns the module text within the specified range.
| GetText(Location, Location) |
Returns the text of the module within the specified locations.
| SaveToFile |
Saves the RAPID module to the specified file path.
| SearchRapidSymbol | General RapidSymbol search method. (Overrides RapidSymbolSearchRapidSymbol(RapidSymbolSearchProperties, String, String).) | |
| SyncPers |
Updates the persistent data of the module with their real values. As this cannot be done while
the task is executing any call in ExecutionState Started will be disregarded and false will be returned.
| ToString | Returns a string that represents the current object. (Inherited from Object.) |
