Saves the RAPID module to the specified file path.
Namespace:
ABB.Robotics.Controllers.RapidDomain
Assembly:
Syntaxpublic void SaveToFile(
string filePath
Parameters
- filePath
- Type: SystemString
Path to the file where the RAPID module should be saved.
Exceptions
ExamplesThis example saves a RAPID module to a file.
private void _gtpusavedialog_Closed(object sender,EventArgs e)
try
if (_gtpusavedialog.DialogResult == System.Windows.Forms.DialogResult.OK)
string stFileName = _gtpusavedialog.FileName;
myModule.SaveToFile(stFileName);
catch (GeneralException ee)
catch (System.Exception ee)
finally
See Also
