Gets the routines defined in the module.
Namespace:
ABB.Robotics.Controllers.RapidDomain
Assembly:
Syntaxpublic Routine[] GetRoutines()
Return Value
Type:
Routine An array of
Routine objects.
Exceptions
RemarksNOTE:When the returned instance is no longer needed you must call its Dispose method.
ExamplesThe method below counts the number of routines in the system.
private int CountRoutines(Controller c)
int result = 0;
Task[] tasks;
try
tasks = c.Rapid.GetTasks();
Modules modules;
foreach (Task t in tasks)
modules = t.GetModules();
Routines routines;
foreach (Module m in modules)
routines = m.GetRoutines();
result += routines.Lenght;
catch (GeneralException ee)
catch (System.Exception ee)
return result;
See Also
