TaskSetProgramPointer Method (ProgramPointer) |
Sets PP to a position in a RAPID module.
Namespace:
ABB.Robotics.Controllers.RapidDomain
Assembly:
Syntax
Exceptions| Exception | Condition |
| ArgumentException | PP is not set because one or both parameters are wrong. |
RemarksAny previous execution stack will be cleared.
PP can only be set within the context of a routine.
If the row is not within the routine where PP is located an exception will be thrown.
See Also
