TaskSetProgramPointer Method (String, String) |
Sets program pointer to the first instruction of a routine (global or local).
Namespace:
ABB.Robotics.Controllers.RapidDomain
Assembly:
Syntaxpublic void SetProgramPointer(
string module,
string routine
Parameters
- module
- Type: SystemString
The name of the module in which the routine is defined. - routine
The name of the routine to which PP will be set.
Exceptions| Exception | Condition |
| ArgumentException | PP is not set because one or both parameters are wrong. |
RemarksAny previous execution stack will be cleared.
ExamplesThis example sets the program pointer to the routine of "MyRoutine" in the module of "MyModule"
using ABB.Robotics;
using ABB.Robotics.Controllers;
using ABB.Robotics.Controllers.RapidDomain;
Controller c = new Controller();
Task[] allTasks = c.Rapid.GetTasks();
Task firstTask = allTasks[0];
firstTask.SetProgramPointer("MyModule","MyRoutine");
See Also
