TaskSetProgramPointer Method (String, Int32) |
Sets PP to a specific row of the current routine.
Namespace:
ABB.Robotics.Controllers.RapidDomain
Assembly:
Syntaxpublic void SetProgramPointer(
string module,
int n
Parameters
- module
- Type: SystemString
The name of the module in which the routine is defined. - n
- Type: SystemInt32
The row number in this module.
RemarksCan be used to set PP to another row in the current routine. If you want to set
PP to a row in a different routine, you must first set PP to that routine.
If the program is executing, the method will return and nothing will happen.
ExamplesThis example sets the program pointer to 20th row of the module of "MyModule"
using ABB.Robotics;
using ABB.Robotics.Controllers;
using ABB.Robotics.Controllers.RapidDomain;
Controller c = new Controller();
Task[] allTasks = c.Rapid.GetTasks();
Task firstTask = allTasks[0];
firstTask.SetProgramPointer("MyModule",20);
See Also
