Click or drag to resize
Orient Methods
The Orient type exposes the following members.
Methods
  NameDescription
Public methodEquals
Indicates whether this instance and a specified object are equal.
(Inherited from ValueType.)
Public methodFillFromEulerAngles
Fills the struct with the quaternian values calculated from Euler angles.
Public methodFillFromString
Fills the struct with a valid rapid string representation.
Public methodGetHashCode
Returns the hash code for this instance.
Public methodGetType
Gets the type of the current instance.
(Inherited from Object.)
Public methodToEulerAngles
Returns the eular angles of the quaternion stored in the struct.
Public methodToString
Returns the string representation of the orient rapid data.
(Overrides ValueTypeToString.)
Top
See Also
