Click or drag to resize
Trace Methods
The Trace type exposes the following members.
Methods
  NameDescription
Public methodStatic memberCode exampleAssert(Boolean)
Checks for a condition and displays an assert message on the FlexPendant, containing a stack trace, if the condition is false. When the condition is false, the assert message, with a stack trace, is also sent out on the network. The message can be displayed in the controller console by enabling the functionality on the controller. Use fpcmd_enable_console_output to enable FlexPendant logging.
Public methodStatic memberCode exampleAssert(Boolean, String)
Checks for a condition and displays an assert message on the FlexPendant, containing a stack trace, if the condition is false. When the condition is false, the message, with a stack trace, is also sent out on the network. The message can be displayed in the controller console by enabling the functionality on the controller. Use fpcmd_enable_console_output to enable FlexPendant logging.
Public methodStatic memberCode exampleAssert(Boolean, String, String)
Checks for a condition and displays an assert message on the FlexPendant, with detailed information and a stack trace, if the condition is false. When the condition is false, the message, with detailed information and a stack trace, is also sent out on the network. The message can be displayed in the controller console by enabling the functionality on the controller. Use fpcmd_enable_console_output to enable FlexPendant logging.
Public methodEquals
Determines whether the specified Object is equal to the current Object.
(Inherited from Object.)
Public methodStatic memberCode exampleFail(String)
An error message, with a stack trace, is displayed on the FlexPendant. The error message, with a stack trace, is also sent out on the network. The error message can be displayed in the controller console by enabling the functionality on the controller. Use fpcmd_enable_console_output to enable FlexPendant logging.
Public methodStatic memberCode exampleFail(String, String)
An error message, with detailed error information and a stack trace, is displayed on the FlexPendant. The error message, with detailed error information and a stack trace, is also sent out on the network. The error message can be displayed in the controller console by enabling the functionality on the controller. Use fpcmd_enable_console_output to enable FlexPendant logging.
Protected methodFinalize
Allows an object to try to free resources and perform other cleanup operations before it is reclaimed by garbage collection.
Public methodGetHashCode
Serves as a hash function for a particular type.
Public methodGetType
Gets the type of the current instance.
Protected methodMemberwiseClone
Creates a shallow copy of the current Object.
Public methodToString
Returns a string that represents the current object.
Public methodStatic memberCode exampleWrite
A trace message is sent out on the network. The message can be displayed in the controller console by enabling the functionality on the controller. Use fpcmd_enable_console_output to enable FlexPendant logging.
Public methodStatic memberCode exampleWriteIf
Checks for a condition and sends a trace message out on the network if the condition is true. The message can be displayed in the controller console by enabling the functionality on the controller. Use fpcmd_enable_console_output to enable FlexPendant logging.
Public methodStatic memberCode exampleWriteLine
Public methodStatic memberCode exampleWriteLineIf
Top
See Also
