Click or drag to resize
TraceWriteIf Method
Checks for a condition and sends a trace message out on the network if the condition is true. The message can be displayed in the controller console by enabling the functionality on the controller. Use fpcmd_enable_console_output to enable FlexPendant logging.
Namespace:  ABB.Robotics.Diagnostics
Assembly:  ABB.Robotics (in ABB.Robotics.dll) Version: 6.5.129.0
Syntax
C#
public static void WriteIf(
	bool condition,
	string message
Parameters
condition
Type: SystemBoolean
true to cause a message to be written; otherwise, false.
message
Type: SystemString
A message to write.
Examples
This example sends a trace message containing the state of an object if the state is not RUNNING.
Trace.WriteIf(myobj.State!=RUNNING, string.Format("Object state: {0}\n", myobj.State.ToString()));
See Also
