Click or drag to resize
TraceAssert Method (Boolean)
Checks for a condition and displays an assert message on the FlexPendant, containing a stack trace, if the condition is false. When the condition is false, the assert message, with a stack trace, is also sent out on the network. The message can be displayed in the controller console by enabling the functionality on the controller. Use fpcmd_enable_console_output to enable FlexPendant logging.
Namespace:  ABB.Robotics.Diagnostics
Assembly:  ABB.Robotics (in ABB.Robotics.dll) Version: 6.5.129.0
Syntax
C#
public static void Assert(
	bool condition
Parameters
condition
Type: SystemBoolean
true to prevent a message being displayed; otherwise, false.
Examples
This example displays and logs an error message if the condition is not fulfilled.
Trace.Assert(myobj.State==RUNNING);
See Also
