TaskModifyPosition Method (String, Int32, ModPosExternalAxis) |
Modifies the data of the first rob target found in the specified row.
Namespace:
ABB.Robotics.Controllers.RapidDomain
Assembly:
Syntax
Exceptions| Exception | Condition |
| ArgumentException | If no data that can be modified is found or the data is wrong.
An exception is also thrown if the active tool and work object differ from the instruction. |
ExamplesThis example modifies the first position of the 10th row.
using ABB.Robotics;
using ABB.Robotics.Controllers;
using ABB.Robotics.Controllers.RapidDomain;
Controller c = new Controller();
Task[] allTasks = c.Rapid.GetTasks();
Task firstTask = allTasks[0];
firstTask.ModifyPosition("MyTest", 10, ModPosExternalAxis.Always);
See Also
