StateObjectsCollectionOnRemoveComplete Method |
Namespace:
Assembly:
Syntaxprotected override void OnRemoveComplete(
int index,
Object value
Parameters
- index
- Type: SystemInt32
The zero-based index at which value can be found. - value
- Type: SystemObject
The value of the element to remove from index.
RemarksNotes to Inheritors: When overriding OnRemoveComplete in a derived class, be sure to call the base class's OnInsertComplete to remove the
StateObject's connections.
See Also
