StateObjectsCollectionOnInsertComplete Method |
Namespace:
Assembly:
Syntaxprotected override void OnInsertComplete(
int index,
Object value
Parameters
- index
- Type: SystemInt32
The zero-based index at which to insert value. - value
- Type: SystemObject
The new value of the element at index.
RemarksNotes to Inheritors: When overriding OnInsertComplete in a derived class, be sure to call the base class's OnInsertComplete to add the
StateObject's connections.
See Also
