FlexPendant Developer Support
FlexPendant Development
References
StateObjectsCollection Class
StateObjectsCollection Methods
Add Method
IndexOf Method
Insert Method
OnClear Method
OnClearComplete Method
OnInsertComplete Method
OnRemoveComplete Method
Remove Method
Insert Method
Inserts an existing
StateObject
into the collection at the specified index.
Namespace:
Assembly:
Syntax
C#
Copy
public
virtual
StateObject
Insert
int
index
StateObject
item
Parameters
index
Type:
System
Int32
The zero-based index location where the item is inserted.
item
Type:
StateObject
The
StateObject
that represents the item to insert.
Return Value
Type:
StateObject
The
StateObject
that was inserted into the collection.
See Also
Reference
ABB.Robotics.Tps.Windows.Forms Namespace
FlexPendant Developer Center | This content is licensed. For details and restrictions, see the
Content License
