ConfigurationDatabaseWrite Method |
Writes a value of a configuration parameter to the configuration database of the controller.
Namespace:
ABB.Robotics.Controllers.ConfigurationDomain
Assembly:
Syntaxpublic void Write(
string value,
params string[] data
Parameters
- value
- Type: SystemString
The value to write. - data
The configuration parameter to write to.
Exceptions
ExamplesController c = new Controller();
ConfigurationDatabase cfg = c.Configuration;
cfg.Write("0", "MOC", "MOTOR_CALIB", "irb_1", "cal_offset");
See Also
