ConfigurationDatabaseRead Method |
Reads the value of a configuration parameter from the configuration database of the controller.
Namespace:
ABB.Robotics.Controllers.ConfigurationDomain
Assembly:
Syntaxpublic string Read(
params string[] data
Parameters
- data
- Type: SystemString
The configuration parameter to read.
Return Value
Type:
StringThe value of the configuration data.
Exceptions
ExamplesController c = new Controller();
ConfigurationDatabase cfg = c.Configuration;
string data = cfg.Read("MOC", "MOTOR_CALIB", "irb_1", "cal_offset");
See Also
