ConfigurationDatabase Methods |
The ConfigurationDatabase type exposes the following members.
| Name | Description | |
| Dispose |
Disposes the managed resources of the instance.
(Overrides SDKDisposeBaseDispose.) | |
| GetDomain |
Returns the configuration domain with the specified name.
| GetDomains |
Returns the domains of the configuration database.
| Read |
Reads the value of a configuration parameter from the configuration database of the controller.
| ToString | Returns a string that represents the current object. (Inherited from Object.) | |
| Write |
Writes a value of a configuration parameter to the configuration database of the controller.
