IProdScrLaunchServicesRegisterApp Method |
Registers application in Taf. A static application should be "blocked" if it or its dependencies are started from Production Screen.
Namespace:
ABB.Robotics.Tps.Taf
Assembly:
ABB.Robotics.Tps.Taf (in ABB.Robotics.Tps.Taf.dll) Version: 6.5.129.0
Syntaxbool RegisterApp(
Object ctrl,
string assembly,
string type,
out Object cookie
Parameters
- ctrl
- Type: SystemObject
Parent control. - assembly
- Type: SystemString
Assembly name. - type
Type name. - cookie
Object used to identify the application when unregistering.
Return Value
Type:
BooleanTrue if Ok, false otherwise.
See Also
