IProdScrLaunchServices Methods |
The IProdScrLaunchServices type exposes the following members.
| Name | Description | |
| ActivateApplication |
Activates application from Production Screen.
| IsAppRunning |
Check if application is running.
| RegisterApp |
Registers application in Taf. A static application should be "blocked" if it or its dependencies are started from Production Screen.
| RegisterProdScr |
Register Production Screen.
| UnregisterApp |
Unregister an application that was registered earlier.
