This event occurs when
Cycle property has changed.
Namespace:
ABB.Robotics.Controllers.RapidDomain
Assembly:
Syntax
Exceptions
RemarksAny subscriber that wants to update their GUI as response to
the event has to redirect the execution to the GUI-thread, using a
Invoke method.
Note: You should not switch to GUI-thread if you don't have to since
a thread switch have impact on performance.
ExamplesThis example sets up a subscription to
CycleChanged event.
bool ITpsViewSetup.Install(object sender, object data)
bool result = true;
try
c = new Controller();
c.Rapid.CycleChanged +=
new CycleChangedEventHandler(r_ExecutionCycleChanged);
catch (System.Exception ee)
result = false;
return result;
private void r_ExecutionCycleChanged(object sender, CycleEventArgs e)
try
this.Invoke(new EventHandler(UpdateUiOnCycleChanged), sender, e);
private void UpdateUiOnCycleChanged(object sender, EventArgs e)
try
CycleEventArgs cycleArg
= (CycleEventArgs)e;
if (cycleArg.Cycle == ExecutionCycle.Continuous)
else
See Also
