Click or drag to resize
RoutineSearchRapidSymbol Method
General RapidSymbol search method.
Namespace:  ABB.Robotics.Controllers.RapidDomain
Assembly:  ABB.Robotics.Controllers (in ABB.Robotics.Controllers.dll) Version: 6.5.129.0
Syntax
C#
public override RapidSymbol[] SearchRapidSymbol(
	RapidSymbolSearchProperties sProps,
	string stDataType,
	string stRegex
Parameters
sProps
Type: ABB.Robotics.Controllers.RapidDomainRapidSymbolSearchProperties
Instance of RapidSymbolSearchProperties with the search properties
stDataType
Type: SystemString
Name of the datatype to search for. Use string.Empty if not of interest.
stRegex
Type: SystemString
The regular expression to search after. Use string.Empty if not of interest.
Return Value
Type: RapidSymbol
An array of RapidSymbol. If no RapidSymbol an array of length zero is returned.
Exceptions
ExceptionCondition
GeneralExceptionA General Exception has occurred.
Examples
This example lists all Rapid data instances and functions of type num declared in task T_ROB1. Name of RapidSymbol and the module where it is declared is added to a listview.
private void btnSearch_Click(object sender,EventArgs e)
       try
           // Create Task if not done
           if (tT_Rob1 == null)
               tT_Rob1 = ctrl.Rapid.GetTask("T_ROB1");
           RapidSymbolSearchProperties sProp =
           RapidSymbolSearchProperties.CreateDefault();
           sProp.SymbolType = SymbolTypes.Function | SymbolTypes.RapidData;
           sProp.IsInUse = false;
           sProp.SearchMethod = SymbolSearchMethod.Block;
           RapidSymbol[] datas = tT_Rob1.SearchRapidSymbol(sProp,"num",string.Empty);
           foreach (RapidSymbol rs in datas)
               ListViewItem li = new ListViewItem(rs.Name);
               // [<TASK>,<MODULE>,...]
               li.SubItems.Add(rs.Scope[1]);
               // Add item
               listView1.Items.Add(li);
       catch (System.Exception ee)
           // Handle any error here
See Also
