Button Methods |
The Button type exposes the following members.
| Name | Description | |
| AccessibilityNotifyClients(AccessibleEvents, Int32) | Notifies the accessibility client applications of the specified AccessibleEvents for the specified child control. (Inherited from Control.) | |
| AccessibilityNotifyClients(AccessibleEvents, Int32, Int32) | Notifies the accessibility client applications of the specified AccessibleEvents for the specified child control . (Inherited from Control.) | |
| AdjustFormScrollbars | (Inherited from ContainerControl.) | |
| BeginInvoke(Delegate) | Executes the specified delegate asynchronously on the thread that the control's underlying handle was created on. (Inherited from Control.) | |
| BeginInvoke(EventHandler) |
(Inherited from TpsControl.) | |
| BeginInvoke(Delegate, Object) | Executes the specified delegate asynchronously with the specified arguments, on the thread that the control's underlying handle was created on. (Inherited from Control.) | |
| BeginInvoke(EventHandler, Object) |
| BeginInvokeEx | Obsolete.
Executes the specified EventHandler asynchronously.
| BringToFront | Brings the control to the front of the z-order. (Inherited from Control.) | |
| Contains | Retrieves a value indicating whether the specified control is a child of the control. (Inherited from Control.) | |
| CreateAccessibilityInstance | Creates a new accessibility object for the control. (Inherited from Control.) | |
| CreateControl | Forces the creation of the visible control, including the creation of the handle and any visible child controls. (Inherited from Control.) | |
| CreateControlsInstance | Creates a new instance of the control collection for the control. (Inherited from Control.) | |
| CreateGraphics | Creates the Graphics for the control. (Inherited from Control.) | |
| CreateHandle | Creates a handle for the control. (Inherited from Control.) | |
| CreateObjRef | Creates an object that contains all the relevant information required to generate a proxy used to communicate with a remote object. (Inherited from MarshalByRefObject.) | |
| DefWndProc | Sends the specified message to the default window procedure. (Inherited from Control.) | |
| DestroyHandle | Destroys the handle associated with the control. (Inherited from Control.) | |
| Dispose | Releases all resources used by the Component. (Inherited from Component.) | |
| Dispose(Boolean) |
Overridden. Releases all resources used by this Button instance.
(Overrides TpsControlDispose(Boolean).) | |
| DoDragDrop | Begins a drag-and-drop operation. (Inherited from Control.) | |
| DrawToBitmap | Supports rendering to the specified bitmap. (Inherited from Control.) | |
| EndInvoke | Retrieves the return value of the asynchronous operation represented by the IAsyncResult passed. (Inherited from Control.) | |
| Finalize |
Destructor.
| FindForm | Retrieves the form that the control is on. (Inherited from Control.) | |
| Focus | Sets input focus to the control. (Inherited from Control.) | |
| GetAccessibilityObjectById | Retrieves the specified AccessibleObject. (Inherited from Control.) | |
| GetAutoSizeMode | Retrieves a value indicating how a control will behave when its AutoSize property is enabled. (Inherited from Control.) | |
| GetChildAtPoint(Point) | Retrieves the child control that is located at the specified coordinates. (Inherited from Control.) | |
| GetChildAtPoint(Point, GetChildAtPointSkip) | Retrieves the child control that is located at the specified coordinates, specifying whether to ignore child controls of a certain type. (Inherited from Control.) | |
| GetContainerControl | Returns the next ContainerControl up the control's chain of parent controls. (Inherited from Control.) | |
| GetForeColor |
Returns the ForeColor used when the control is enabled or disabled.
| GetLifetimeService | Retrieves the current lifetime service object that controls the lifetime policy for this instance. (Inherited from MarshalByRefObject.) | |
| GetNextControl | Retrieves the next control forward or back in the tab order of child controls. (Inherited from Control.) | |
| GetPreferredSize | Retrieves the size of a rectangular area into which a control can be fitted. (Inherited from Control.) | |
| GetScaledBounds | Retrieves the bounds within which the control is scaled. (Inherited from Control.) | |
| GetScrollState | Determines whether the specified flag has been set. (Inherited from ScrollableControl.) | |
| GetService | (Inherited from Component.) | |
| GetStyle | Retrieves the value of the specified control style bit for the control. (Inherited from Control.) | |
| GetTopLevel | Determines if the control is a top-level control. (Inherited from Control.) | |
| Hide | Conceals the control from the user. (Inherited from Control.) | |
| InitializeLifetimeService | Obtains a lifetime service object to control the lifetime policy for this instance. (Inherited from MarshalByRefObject.) | |
| InitLayout | Called after the control has been added to another container. (Inherited from Control.) | |
| Invalidate |
Invalidates the entire surface of the control and causes the control to be redrawn.
| Invalidate(Region) | Invalidates the specified region of the control (adds it to the control's update region, which is the area that will be repainted at the next paint operation), and causes a paint message to be sent to the control. (Inherited from Control.) | |
| Invalidate(Boolean) | Invalidates a specific region of the control and causes a paint message to be sent to the control. Optionally, invalidates the child controls assigned to the control. (Inherited from Control.) | |
| Invalidate(Rectangle) | Invalidates the specified region of the control (adds it to the control's update region, which is the area that will be repainted at the next paint operation), and causes a paint message to be sent to the control. (Inherited from Control.) | |
| Invalidate(Region, Boolean) | Invalidates the specified region of the control (adds it to the control's update region, which is the area that will be repainted at the next paint operation), and causes a paint message to be sent to the control. Optionally, invalidates the child controls assigned to the control. (Inherited from Control.) | |
| Invalidate(Rectangle, Boolean) | Invalidates the specified region of the control (adds it to the control's update region, which is the area that will be repainted at the next paint operation), and causes a paint message to be sent to the control. Optionally, invalidates the child controls assigned to the control. (Inherited from Control.) | |
| Invoke(Delegate) | Executes the specified delegate on the thread that owns the control's underlying window handle. (Inherited from Control.) | |
| Invoke(Delegate, Object) | Executes the specified delegate, on the thread that owns the control's underlying window handle, with the specified list of arguments. (Inherited from Control.) | |
| InvokeGotFocus | Raises the GotFocus event for the specified control. (Inherited from Control.) | |
| InvokeLostFocus | Raises the LostFocus event for the specified control. (Inherited from Control.) | |
| InvokeOnClick | Raises the Click event for the specified control. (Inherited from Control.) | |
| InvokePaint | Raises the Paint event for the specified control. (Inherited from Control.) | |
| InvokePaintBackground | Raises the PaintBackground event for the specified control. (Inherited from Control.) | |
| IsInputChar | Determines if a character is an input character that the control recognizes. (Inherited from Control.) | |
| IsInputKey | Determines whether the specified key is a regular input key or a special key that requires preprocessing. (Inherited from Control.) | |
| MemberwiseClone(Boolean) | Creates a shallow copy of the current MarshalByRefObject object. (Inherited from MarshalByRefObject.) | |
| NotifyInvalidate | Raises the Invalidated event with a specified region of the control to invalidate. (Inherited from Control.) | |
| OnAutoSizeChanged | Raises the AutoSizeChanged event. (Inherited from Control.) | |
| OnAutoValidateChanged | Raises the AutoValidateChanged event. (Inherited from ContainerControl.) | |
| OnBackColorChanged | Raises the BackColorChanged event. (Inherited from Control.) | |
| OnBackgroundImageChanged | Raises the BackgroundImageChanged event. (Inherited from Control.) | |
| OnBackgroundImageLayoutChanged | Raises the BackgroundImageLayoutChanged event. (Inherited from Control.) | |
| OnBindingContextChanged | Raises the BindingContextChanged event. (Inherited from Control.) | |
| OnCausesValidationChanged | Raises the CausesValidationChanged event. (Inherited from Control.) | |
| OnChangeUICues | Raises the ChangeUICues event. (Inherited from Control.) | |
| OnClick | Raises the Click event. (Inherited from Control.) | |
| OnClientSizeChanged | Raises the ClientSizeChanged event. (Inherited from Control.) | |
| OnContextMenuChanged | Raises the ContextMenuChanged event. (Inherited from Control.) | |
| OnContextMenuStripChanged | Raises the ContextMenuStripChanged event. (Inherited from Control.) | |
| OnControlAdded | Raises the ControlAdded event. (Inherited from Control.) | |
| OnControlRemoved | Raises the ControlRemoved event. (Inherited from Control.) | |
| OnCreateControl | Raises the CreateControl event. (Inherited from UserControl.) | |
| OnCursorChanged | Raises the CursorChanged event. (Inherited from Control.) | |
| OnDockChanged | Raises the DockChanged event. (Inherited from Control.) | |
| OnDoubleClick | Raises the DoubleClick event. (Inherited from Control.) | |
| OnDragDrop | Raises the DragDrop event. (Inherited from Control.) | |
| OnDragEnter | Raises the DragEnter event. (Inherited from Control.) | |
| OnDragLeave | Raises the DragLeave event. (Inherited from Control.) | |
| OnDragOver | Raises the DragOver event. (Inherited from Control.) | |
| OnEnabledChanged |
Overridden. Raises the EnabledChanged event.
(Overrides ControlOnEnabledChanged(EventArgs).) | |
| OnEnter | Raises the Enter event. (Inherited from Control.) | |
| OnFontChanged |
Raises the FontChanged event.
| OnForeColorChanged | Raises the ForeColorChanged event. (Inherited from Control.) | |
| OnGiveFeedback | Raises the GiveFeedback event. (Inherited from Control.) | |
| OnGotFocus | Raises the GotFocus event. (Inherited from Control.) | |
| OnHandleCreated | Raises the HandleCreated event. (Inherited from Control.) | |
| OnHandleDestroyed | Raises the HandleDestroyed event. (Inherited from Control.) | |
| OnHelpRequested | Raises the HelpRequested event. (Inherited from Control.) | |
| OnImeModeChanged | Raises the ImeModeChanged event. (Inherited from Control.) | |
| OnInvalidated | Raises the Invalidated event. (Inherited from Control.) | |
| OnKeyDown | Raises the KeyDown event. (Inherited from Control.) | |
| OnKeyPress | Raises the KeyPress event. (Inherited from Control.) | |
| OnKeyUp | Raises the KeyUp event. (Inherited from Control.) | |
| OnLayout | (Inherited from ContainerControl.) | |
| OnLeave | Raises the Leave event. (Inherited from Control.) | |
| OnLoad | Raises the Load event. (Inherited from UserControl.) | |
| OnLocationChanged | Raises the LocationChanged event. (Inherited from Control.) | |
| OnLostFocus | Raises the LostFocus event. (Inherited from Control.) | |
| OnMarginChanged | Raises the MarginChanged event. (Inherited from Control.) | |
| OnMouseCaptureChanged | Raises the MouseCaptureChanged event. (Inherited from Control.) | |
| OnMouseClick | Raises the MouseClick event. (Inherited from Control.) | |
| OnMouseDoubleClick | Raises the MouseDoubleClick event. (Inherited from Control.) | |
| OnMouseDown |
Overridden. Raises the MouseDown event.
(Overrides UserControlOnMouseDown(MouseEventArgs).) | |
| OnMouseEnter | Raises the MouseEnter event. (Inherited from Control.) | |
| OnMouseHover | Raises the MouseHover event. (Inherited from Control.) | |
| OnMouseLeave | Raises the MouseLeave event. (Inherited from Control.) | |
| OnMouseMove | Raises the MouseMove event. (Inherited from Control.) | |
| OnMouseUp |
Overridden. Raises the OnMouseUp event.
(Overrides ControlOnMouseUp(MouseEventArgs).) | |
| OnMouseWheel | Raises the MouseWheel event. (Inherited from ScrollableControl.) | |
| OnMove | Raises the Move event. (Inherited from Control.) | |
| OnNotifyMessage | Notifies the control of Windows messages. (Inherited from Control.) | |
| OnPaddingChanged | Raises the PaddingChanged event. (Inherited from ScrollableControl.) | |
| OnPaint |
Overridden. Raises the Paint event.
(Overrides ControlOnPaint(PaintEventArgs).) | |
| OnPaintBackground |
Overridden. Prevents painting the background of the Button control.
(Overrides ScrollableControlOnPaintBackground(PaintEventArgs).) | |
| OnParentBackColorChanged | Raises the BackColorChanged event when the BackColor property value of the control's container changes. (Inherited from Control.) | |
| OnParentBackgroundImageChanged | Raises the BackgroundImageChanged event when the BackgroundImage property value of the control's container changes. (Inherited from Control.) | |
| OnParentBindingContextChanged | Raises the BindingContextChanged event when the BindingContext property value of the control's container changes. (Inherited from Control.) | |
| OnParentChanged | (Inherited from ContainerControl.) | |
| OnParentCursorChanged | Raises the CursorChanged event. (Inherited from Control.) | |
| OnParentEnabledChanged | Raises the EnabledChanged event when the Enabled property value of the control's container changes. (Inherited from Control.) | |
| OnParentFontChanged | Raises the FontChanged event when the Font property value of the control's container changes. (Inherited from Control.) | |
| OnParentForeColorChanged | Raises the ForeColorChanged event when the ForeColor property value of the control's container changes. (Inherited from Control.) | |
| OnParentRightToLeftChanged | Raises the RightToLeftChanged event when the RightToLeft property value of the control's container changes. (Inherited from Control.) | |
| OnParentVisibleChanged | Raises the VisibleChanged event when the Visible property value of the control's container changes. (Inherited from Control.) | |
| OnPreviewKeyDown | Raises the PreviewKeyDown event. (Inherited from Control.) | |
| OnPrint | Raises the Paint event. (Inherited from Control.) | |
| OnPropertyChanged |
Inheritors must call base method in order to notify value for Binding
| OnQueryContinueDrag | Raises the QueryContinueDrag event. (Inherited from Control.) | |
| OnRegionChanged | Raises the RegionChanged event. (Inherited from Control.) | |
| OnResize | (Inherited from UserControl.) | |
| OnRightToLeftChanged | (Inherited from ScrollableControl.) | |
| OnScroll | Raises the Scroll event. (Inherited from ScrollableControl.) | |
| OnSizeChanged | Raises the SizeChanged event. (Inherited from Control.) | |
| OnStyleChanged | Raises the StyleChanged event. (Inherited from Control.) | |
| OnSystemColorsChanged | Raises the SystemColorsChanged event. (Inherited from Control.) | |
| OnTabIndexChanged | Raises the TabIndexChanged event. (Inherited from Control.) | |
| OnTabStopChanged | Raises the TabStopChanged event. (Inherited from Control.) | |
| OnTextChanged | Raises the TextChanged event. (Inherited from Control.) | |
| OnValidated | Raises the Validated event. (Inherited from Control.) | |
| OnValidating | Raises the Validating event. (Inherited from Control.) | |
| OnVisibleChanged | (Inherited from ScrollableControl.) | |
| PerformAutoScale | Performs scaling of the container control and its children. (Inherited from ContainerControl.) | |
| PerformLayout | Forces the control to apply layout logic to all its child controls. (Inherited from Control.) | |
| PerformLayout(Control, String) | Forces the control to apply layout logic to all its child controls. (Inherited from Control.) | |
| PointToClient | Computes the location of the specified screen point into client coordinates. (Inherited from Control.) | |
| PointToScreen | Computes the location of the specified client point into screen coordinates. (Inherited from Control.) | |
| PreProcessControlMessage | Preprocesses keyboard or input messages within the message loop before they are dispatched. (Inherited from Control.) | |
| PreProcessMessage | Preprocesses keyboard or input messages within the message loop before they are dispatched. (Inherited from Control.) | |
| ProcessCmdKey | (Inherited from ContainerControl.) | |
| ProcessDialogChar | (Inherited from ContainerControl.) | |
| ProcessDialogKey | (Inherited from ContainerControl.) | |
| ProcessKeyEventArgs | Processes a key message and generates the appropriate control events. (Inherited from Control.) | |
| ProcessKeyMessage | Processes a keyboard message. (Inherited from Control.) | |
| ProcessKeyPreview | Previews a keyboard message. (Inherited from Control.) | |
| ProcessMnemonic | (Inherited from ContainerControl.) | |
| ProcessTabKey | Selects the next available control and makes it the active control. (Inherited from ContainerControl.) | |
| RaiseDragEvent | Raises the appropriate drag event. (Inherited from Control.) | |
| RaiseKeyEvent | Raises the appropriate key event. (Inherited from Control.) | |
| RaiseMouseEvent | Raises the appropriate mouse event. (Inherited from Control.) | |
| RaisePaintEvent | Raises the appropriate paint event. (Inherited from Control.) | |
| RecreateHandle | Forces the re-creation of the handle for the control. (Inherited from Control.) | |
| RectangleToClient | Computes the size and location of the specified screen rectangle in client coordinates. (Inherited from Control.) | |
| RectangleToScreen | Computes the size and location of the specified client rectangle in screen coordinates. (Inherited from Control.) | |
| Refresh | Forces the control to invalidate its client area and immediately redraw itself and any child controls. (Inherited from Control.) | |
| ResetBackColor | Resets the BackColor property to its default value. (Inherited from Control.) | |
| ResetBindings | Causes a control bound to the BindingSource to reread all the items in the list and refresh their displayed values. (Inherited from Control.) | |
| ResetCursor | Resets the Cursor property to its default value. (Inherited from Control.) | |
| ResetFont | Resets the Font property to its default value. (Inherited from Control.) | |
| ResetForeColor | Resets the ForeColor property to its default value. (Inherited from Control.) | |
| ResetImeMode | Resets the ImeMode property to its default value. (Inherited from Control.) | |
| ResetMouseEventArgs | Resets the control to handle the MouseLeave event. (Inherited from Control.) | |
| ResetRightToLeft | Resets the RightToLeft property to its default value. (Inherited from Control.) | |
| ResetText | Resets the Text property to its default value. (Inherited from Control.) | |
| ResumeLayout | Resumes usual layout logic. (Inherited from Control.) | |
| ResumeLayout(Boolean) | Resumes usual layout logic, optionally forcing an immediate layout of pending layout requests. (Inherited from Control.) | |
| RtlTranslateAlignment(HorizontalAlignment) | Converts the specified HorizontalAlignment to the appropriate HorizontalAlignment to support right-to-left text. (Inherited from Control.) | |
| RtlTranslateAlignment(LeftRightAlignment) | Converts the specified LeftRightAlignment to the appropriate LeftRightAlignment to support right-to-left text. (Inherited from Control.) | |
| RtlTranslateAlignment(ContentAlignment) | Converts the specified ContentAlignment to the appropriate ContentAlignment to support right-to-left text. (Inherited from Control.) | |
| RtlTranslateContent | Converts the specified ContentAlignment to the appropriate ContentAlignment to support right-to-left text. (Inherited from Control.) | |
| RtlTranslateHorizontal | Converts the specified HorizontalAlignment to the appropriate HorizontalAlignment to support right-to-left text. (Inherited from Control.) | |
| RtlTranslateLeftRight | Converts the specified LeftRightAlignment to the appropriate LeftRightAlignment to support right-to-left text. (Inherited from Control.) | |
| Scale(Single) | Obsolete. Scales the control and any child controls. (Inherited from Control.) | |
| Scale(SizeF) | Scales the control and all child controls by the specified scaling factor. (Inherited from Control.) | |
| Scale(Single, Single) | Obsolete. Scales the entire control and any child controls. (Inherited from Control.) | |
| ScaleControl | (Inherited from ScrollableControl.) | |
| ScaleCore | (Inherited from ScrollableControl.) | |
| ScrollControlIntoView | Scrolls the specified child control into view on an auto-scroll enabled control. (Inherited from ScrollableControl.) | |
| ScrollToControl | Calculates the scroll offset to the specified child control. (Inherited from ScrollableControl.) | |
| Select | Activates the control. (Inherited from Control.) | |
| Select(Boolean, Boolean) | (Inherited from ContainerControl.) | |
| SelectNextControl | Activates the next control. (Inherited from Control.) | |
| SendToBack | Sends the control to the back of the z-order. (Inherited from Control.) | |
| SetAutoScrollMargin | Sets the size of the auto-scroll margins. (Inherited from ScrollableControl.) | |
| SetAutoSizeMode | Sets a value indicating how a control will behave when its AutoSize property is enabled. (Inherited from Control.) | |
| SetBounds(Int32, Int32, Int32, Int32) | Sets the bounds of the control to the specified location and size. (Inherited from Control.) | |
| SetBounds(Int32, Int32, Int32, Int32, BoundsSpecified) | Sets the specified bounds of the control to the specified location and size. (Inherited from Control.) | |
| SetBoundsCore | Performs the work of setting the specified bounds of this control. (Inherited from Control.) | |
| SetClientSizeCore | Sets the size of the client area of the control. (Inherited from Control.) | |
| SetDisplayRectLocation | Positions the display window to the specified value. (Inherited from ScrollableControl.) | |
| SetScrollState | Sets the specified scroll state flag. (Inherited from ScrollableControl.) | |
| SetStyle | Sets a specified ControlStyles flag to either true or false. (Inherited from Control.) | |
| SetTopLevel | Sets the control as the top-level control. (Inherited from Control.) | |
| SetVisibleCore | Sets the control to the specified visible state. (Inherited from Control.) | |
| Show | Displays the control to the user. (Inherited from Control.) | |
| SizeFromClientSize | Determines the size of the entire control from the height and width of its client area. (Inherited from Control.) | |
| SuspendLayout | Temporarily suspends the layout logic for the control. (Inherited from Control.) | |
| ToString | Returns a String containing the name of the Component, if any. This method should not be overridden. (Inherited from Component.) | |
| Update | Causes the control to redraw the invalidated regions within its client area. (Inherited from Control.) | |
| UpdateBounds | Updates the bounds of the control with the current size and location. (Inherited from Control.) | |
| UpdateBounds(Int32, Int32, Int32, Int32) | Updates the bounds of the control with the specified size and location. (Inherited from Control.) | |
| UpdateBounds(Int32, Int32, Int32, Int32, Int32, Int32) | Updates the bounds of the control with the specified size, location, and client size. (Inherited from Control.) | |
| UpdateDefaultButton | When overridden by a derived class, updates which button is the default button. (Inherited from ContainerControl.) | |
| UpdateStyles | Forces the assigned styles to be reapplied to the control. (Inherited from Control.) | |
| UpdateZOrder | Updates the control in its parent's z-order. (Inherited from Control.) | |
| Validate | Verifies the value of the control losing focus by causing the Validating and Validated events to occur, in that order. (Inherited from ContainerControl.) | |
| Validate(Boolean) | Verifies the value of the control that is losing focus; conditionally dependent on whether automatic validation is turned on. (Inherited from ContainerControl.) | |
| ValidateChildren | (Inherited from UserControl.) | |
| ValidateChildren(ValidationConstraints) | (Inherited from UserControl.) | |
| WndProc | (Inherited from UserControl.) |
