DeviceDriverStream Methods |
The DeviceDriverStream type exposes the following members.
| Name | Description | |
| BeginRead | Begins an asynchronous read operation. (Inherited from Stream.) | |
| BeginWrite | Begins an asynchronous write operation. (Inherited from Stream.) | |
| Close |
Closes the stream object.
(Overrides StreamClose.) | |
| CreateObjRef | Creates an object that contains all the relevant information required to generate a proxy used to communicate with a remote object. (Inherited from MarshalByRefObject.) | |
| CreateWaitHandle | Obsolete. Allocates a WaitHandle object. (Inherited from Stream.) | |
| Dispose | Releases all resources used by the Stream. (Inherited from Stream.) | |
| Dispose(Boolean) | Releases the unmanaged resources used by the Stream and optionally releases the managed resources. (Inherited from Stream.) | |
| EndRead | Waits for the pending asynchronous read to complete. (Inherited from Stream.) | |
| EndWrite | Ends an asynchronous write operation. (Inherited from Stream.) | |
| Finalize | Allows an object to try to free resources and perform other cleanup operations before it is reclaimed by garbage collection. (Inherited from Object.) | |
| Flush |
Flush data to stream, currently not implemented, all writes are
imediate against the controller.
(Overrides StreamFlush.) | |
| GetLifetimeService | Retrieves the current lifetime service object that controls the lifetime policy for this instance. (Inherited from MarshalByRefObject.) | |
| InitializeLifetimeService | Obtains a lifetime service object to control the lifetime policy for this instance. (Inherited from MarshalByRefObject.) | |
| MemberwiseClone(Boolean) | Creates a shallow copy of the current MarshalByRefObject object. (Inherited from MarshalByRefObject.) | |
| Read |
Reads a sequence of bytes from the stream.
(Overrides StreamRead(Byte, Int32, Int32).) | |
| ReadByte | Reads a byte from the stream and advances the position within the stream by one byte, or returns -1 if at the end of the stream. (Inherited from Stream.) | |
| Seek |
Not supported.
(Overrides StreamSeek(Int64, SeekOrigin).) | |
| SetLength |
Not supported.
(Overrides StreamSetLength(Int64).) | |
| ToString | Returns a string that represents the current object. (Inherited from Object.) | |
| Write |
Writes a sequence of bytes to the stream.
(Overrides StreamWrite(Byte, Int32, Int32).) | |
| WriteByte | Writes a byte to the current position in the stream and advances the position within the stream by one byte. (Inherited from Stream.) |
