DeviceDriverStreamWrite Method |
Writes a sequence of bytes to the stream.
Namespace:
ABB.Robotics.Controllers
Assembly:
Syntaxpublic override void Write(
byte[] buffer,
int offset,
int count
Parameters
- buffer
- Type: SystemByte
Buffer for write data. - offset
- Type: SystemInt32
Offset in buffer to write. - count
- Type: SystemInt32
Maximum number of bytes to write.
Return Value
Type:
Acutal number of bytes read.
See Also
