FlexPendant Developer Support
FlexPendant Development
References
ABB.Robotics.Controllers.RapidDomain
Num Structure
Num Methods
FillFromNum Method
FillFromString Method
ToString Method
Num
Fills the struct with a valid rapid string representation.
Namespace:
Assembly:
ABB.Robotics (in ABB.Robotics.dll) Version: 6.5.129.0
Syntax
C#
Copy
public
void
FillFromString
string
newValue
Parameters
newValue
Type:
System
String
The new value stored by the struct.
Implements
IRapidData
FillFromString(String)
Exceptions
Exception
Condition
RapidDataFormatException
newValue
does not represent the num data type.
See Also
Reference
Num Structure
ABB.Robotics.Controllers.RapidDomain Namespace
FlexPendant Developer Center | This content is licensed. For details and restrictions, see the
Content License
