Num Methods |
The Num type exposes the following members.
| Name | Description | |
| Equals | Indicates whether this instance and a specified object are equal. (Inherited from ValueType.) | |
| FillFromNum |
Fills the struct with a double value.
| FillFromString |
Fills the struct with a valid rapid string representation.
| GetHashCode | Returns the hash code for this instance. (Inherited from ValueType.) | |
| ToString |
Returns the string representation of the num rapid data.
(Overrides ValueTypeToString.) |
