TpsViewAttribute Class |
Namespace: ABB.Robotics.Tps.Taf
public class TpsViewAttribute : Attribute
The TpsViewAttribute type exposes the following members.
| Name | Description | |
| TpsViewAttribute(String, String, String, String, String, StartPanelLocation, TpsViewType) |
Initializes a new instance of TpsViewAttribute
| TpsViewAttribute(String, String, String, String, String, StartPanelLocation, TpsViewType, TpsViewStartupTypes) |
| TpsViewAttribute(String, String, String, String, String, StartPanelLocation, TpsViewType, String) |
| TpsViewAttribute(String, String, String, String, String, StartPanelLocation, TpsViewType, String, TpsViewStartupTypes) |
| ABBMenuImagePath |
Gets the path to the image associated with the view in the start panel.
| AssemblyName |
Gets the name of the assembly.
| Closeable |
Defines if the view is closeable or not, its default value is true.
| ResourceAssembly |
Gets the name of the resource assembly associated with the view.
| StartPanelLocation |
Gets the start panel location of the view.
| StartupType |
Gets the startup type for the view.
| TaskBarImagePath |
Gets the path to the image associated with the view in the start panel and in the taskbar.
| Text |
Gets the text associated with the view in the ABBMenu (start panel) and in the taskbar.
| TpsViewClassName |
Gets the fully qualified name of the TpsView class.
| TpsViewType |
Gets the type of the view.
| TypeId | When implemented in a derived class, gets a unique identifier for this Attribute. (Inherited from Attribute.) |
| Equals | Returns a value that indicates whether this instance is equal to a specified object. (Inherited from Attribute.) | |
| Finalize | Allows an object to try to free resources and perform other cleanup operations before it is reclaimed by garbage collection. (Inherited from Object.) | |
| GetHashCode | Returns the hash code for this instance. (Inherited from Attribute.) | |
| IsDefaultAttribute | When overridden in a derived class, indicates whether the value of this instance is the default value for the derived class. (Inherited from Attribute.) | |
| Match | When overridden in a derived class, returns a value that indicates whether this instance equals a specified object. (Inherited from Attribute.) | |
| ToString | Returns a string that represents the current object. (Inherited from Object.) |
