TpsViewAttribute Properties |
The TpsViewAttribute type exposes the following members.
| Name | Description | |
| ABBMenuImagePath |
Gets the path to the image associated with the view in the start panel.
| AssemblyName |
Gets the name of the assembly.
| Closeable |
Defines if the view is closeable or not, its default value is true.
| ResourceAssembly |
Gets the name of the resource assembly associated with the view.
| StartPanelLocation |
Gets the start panel location of the view.
| StartupType |
Gets the startup type for the view.
| TaskBarImagePath |
Gets the path to the image associated with the view in the start panel and in the taskbar.
| Text |
Gets the text associated with the view in the ABBMenu (start panel) and in the taskbar.
| TpsViewClassName |
Gets the fully qualified name of the TpsView class.
| TpsViewType |
Gets the type of the view.
| TypeId | When implemented in a derived class, gets a unique identifier for this Attribute. (Inherited from Attribute.) |
