Gets a
Signal object referring to a specific IO signal.
Namespace:
ABB.Robotics.Controllers.IOSystemDomain
Assembly:
Syntaxpublic Signal GetSignal(
string signalName
Parameters
- signalName
- Type: SystemString
Name of the signal.
Return Value
Type:
SignalA
Signal object used to access the signal. If the signal does not exist, the return value is
null.
Exceptions
See Also
