Click or drag to resize
RadioButton Methods
The RadioButton type exposes the following members.
Methods
  NameDescription
Protected methodAccessibilityNotifyClients(AccessibleEvents, Int32)
Notifies the accessibility client applications of the specified AccessibleEvents for the specified child control.
(Inherited from Control.)
Protected methodAccessibilityNotifyClients(AccessibleEvents, Int32, Int32)
Notifies the accessibility client applications of the specified AccessibleEvents for the specified child control .
Protected methodAdjustFormScrollbars (Inherited from ContainerControl.)
Public methodBeginInvoke(Delegate)
Executes the specified delegate asynchronously on the thread that the control's underlying handle was created on.
Public methodBeginInvoke(EventHandler)
(Inherited from TpsControl.)
Public methodBeginInvoke(Delegate, Object)
Executes the specified delegate asynchronously with the specified arguments, on the thread that the control's underlying handle was created on.
Public methodBeginInvoke(EventHandler, Object)
Public methodBeginInvokeEx Obsolete.
Executes the specified EventHandler asynchronously.
Public methodBringToFront
Brings the control to the front of the z-order.
Public methodContains
Retrieves a value indicating whether the specified control is a child of the control.
Protected methodCreateAccessibilityInstance
Creates a new accessibility object for the control.
Public methodCreateControl
Forces the creation of the visible control, including the creation of the handle and any visible child controls.
Protected methodCreateControlsInstance
Creates a new instance of the control collection for the control.
Public methodCreateGraphics
Creates the Graphics for the control.
Protected methodCreateHandle
Creates a handle for the control.
Public methodCreateObjRef
Creates an object that contains all the relevant information required to generate a proxy used to communicate with a remote object.
(Inherited from MarshalByRefObject.)
Protected methodDefWndProc
Sends the specified message to the default window procedure.
Protected methodDestroyHandle
Destroys the handle associated with the control.
Public methodDispose
Releases all resources used by the Component.
(Inherited from Component.)
Protected methodDispose(Boolean)
Overridden. Release managed and native resources of the instance.
Public methodDoDragDrop
Begins a drag-and-drop operation.
Public methodDrawToBitmap
Supports rendering to the specified bitmap.
Public methodEndInvoke
Retrieves the return value of the asynchronous operation represented by the IAsyncResult passed.
Public methodEquals
Determines whether the specified Object is equal to the current Object.
(Inherited from Object.)
Protected methodFinalize
Destructor.
Public methodFindForm
Retrieves the form that the control is on.
Public methodFocus
Sets input focus to the control.
Protected methodGetAccessibilityObjectById
Retrieves the specified AccessibleObject.
Protected methodGetAutoSizeMode
Retrieves a value indicating how a control will behave when its AutoSize property is enabled.
Public methodGetChildAtPoint(Point)
Retrieves the child control that is located at the specified coordinates.
Public methodGetChildAtPoint(Point, GetChildAtPointSkip)
Retrieves the child control that is located at the specified coordinates, specifying whether to ignore child controls of a certain type.
Public methodGetContainerControl
Returns the next ContainerControl up the control's chain of parent controls.
Protected methodGetForeColor
Returns the ForeColor used when the control is enabled or disabled.
Public methodGetHashCode
Serves as a hash function for a particular type.
Public methodGetLifetimeService
Retrieves the current lifetime service object that controls the lifetime policy for this instance.
Public methodGetNextControl
Retrieves the next control forward or back in the tab order of child controls.
Public methodGetPreferredSize
Retrieves the size of a rectangular area into which a control can be fitted.
Protected methodGetScaledBounds
Retrieves the bounds within which the control is scaled.
Protected methodGetScrollState
Determines whether the specified flag has been set.
(Inherited from ScrollableControl.)
Protected methodGetService
Returns an object that represents a service provided by the Component or by its Container.
Protected methodGetStyle
Retrieves the value of the specified control style bit for the control.
Protected methodGetTopLevel
Determines if the control is a top-level control.
Public methodGetType
Gets the type of the current instance.
Public methodHide
Conceals the control from the user.
Public methodInitializeLifetimeService
Obtains a lifetime service object to control the lifetime policy for this instance.
Protected methodInitLayout
Called after the control has been added to another container.
Public methodInvalidate
Invalidates the entire surface of the control and causes the control to be redrawn.
Public methodInvalidate(Region)
Invalidates the specified region of the control (adds it to the control's update region, which is the area that will be repainted at the next paint operation), and causes a paint message to be sent to the control.
Public methodInvalidate(Boolean)
Invalidates a specific region of the control and causes a paint message to be sent to the control. Optionally, invalidates the child controls assigned to the control.
Public methodInvalidate(Rectangle)
Public methodInvalidate(Region, Boolean)
Invalidates the specified region of the control (adds it to the control's update region, which is the area that will be repainted at the next paint operation), and causes a paint message to be sent to the control. Optionally, invalidates the child controls assigned to the control.
Public methodInvalidate(Rectangle, Boolean)
Public methodInvoke(Delegate)
Executes the specified delegate on the thread that owns the control's underlying window handle.
Public methodInvoke(Delegate, Object)
Executes the specified delegate, on the thread that owns the control's underlying window handle, with the specified list of arguments.
Public methodInvoke(EventHandler, Object)
Protected methodInvokeGotFocus
Raises the GotFocus event for the specified control.
Protected methodInvokeLostFocus
Raises the LostFocus event for the specified control.
Protected methodInvokeOnClick
Raises the Click event for the specified control.
Protected methodInvokePaint
Raises the Paint event for the specified control.
Protected methodInvokePaintBackground
Raises the PaintBackground event for the specified control.
Protected methodIsInputChar
Determines if a character is an input character that the control recognizes.
Protected methodIsInputKey
Determines whether the specified key is a regular input key or a special key that requires preprocessing.
Protected methodMemberwiseClone
Creates a shallow copy of the current Object.
Protected methodMemberwiseClone(Boolean)
Creates a shallow copy of the current MarshalByRefObject object.
Protected methodNotifyInvalidate
Raises the Invalidated event with a specified region of the control to invalidate.
Protected methodOnAutoSizeChanged
Raises the AutoSizeChanged event.
Protected methodOnAutoValidateChanged
Raises the AutoValidateChanged event.
Protected methodOnBackColorChanged
Raises the BackColorChanged event.
Protected methodOnBackgroundImageChanged
Raises the BackgroundImageChanged event.
Protected methodOnBackgroundImageLayoutChanged (Inherited from Control.)
Protected methodOnBindingContextChanged
Raises the BindingContextChanged event.
Protected methodOnCausesValidationChanged
Raises the CausesValidationChanged event.
Protected methodOnChangeUICues
Raises the ChangeUICues event.
Protected methodOnCheckedChanged
Overridden, used by inheritors.
Protected methodOnClick
Overridden, to be used by inheritors to check the control when clicked.
(Overrides ControlOnClick(EventArgs).)
Protected methodOnClientSizeChanged
Raises the ClientSizeChanged event.
Protected methodOnContextMenuChanged
Raises the ContextMenuChanged event.
Protected methodOnContextMenuStripChanged
Raises the ContextMenuStripChanged event.
Protected methodOnControlAdded
Raises the ControlAdded event.
Protected methodOnControlRemoved
Raises the ControlRemoved event.
Protected methodOnCreateControl
Raises the CreateControl event.
(Inherited from UserControl.)
Protected methodOnCursorChanged
Raises the CursorChanged event.
Protected methodOnDockChanged
Raises the DockChanged event.
Protected methodOnDoubleClick
Raises the DoubleClick event.
Protected methodOnDragDrop
Raises the DragDrop event.
Protected methodOnDragEnter
Raises the DragEnter event.
Protected methodOnDragLeave
Raises the DragLeave event.
Protected methodOnDragOver
Raises the DragOver event.
Protected methodOnEnabledChanged
(Overrides ControlOnEnabledChanged(EventArgs).)
Protected methodOnEnter
Raises the Enter event.
Protected methodOnFontChanged
Raises the FontChanged event.
Protected methodOnForeColorChanged
Raises the ForeColorChanged event.
Protected methodOnGiveFeedback
Raises the GiveFeedback event.
Protected methodOnGotFocus
Raises the GotFocus event.
Protected methodOnHandleCreated
Raises the HandleCreated event.
Protected methodOnHandleDestroyed
Raises the HandleDestroyed event.
Protected methodOnHelpRequested
Raises the HelpRequested event.
Protected methodOnImeModeChanged
Raises the ImeModeChanged event.
Protected methodOnInvalidated
Raises the Invalidated event.
Protected methodOnKeyDown
Raises the KeyDown event.
Protected methodOnKeyPress
(Overrides ControlOnKeyPress(KeyPressEventArgs).)
Protected methodOnKeyUp
Raises the KeyUp event.
Protected methodOnLayout (Inherited from ContainerControl.)
Protected methodOnLeave
Raises the Leave event.
Protected methodOnLoad
Raises the Load event.
Protected methodOnLocationChanged
Raises the LocationChanged event.
Protected methodOnLostFocus
Raises the LostFocus event.
Protected methodOnMarginChanged
Raises the MarginChanged event.
Protected methodOnMouseCaptureChanged
Raises the MouseCaptureChanged event.
Protected methodOnMouseClick
Raises the MouseClick event.
Protected methodOnMouseDoubleClick
Raises the MouseDoubleClick event.
Protected methodOnMouseDown (Inherited from UserControl.)
Protected methodOnMouseEnter
Raises the MouseEnter event.
Protected methodOnMouseHover
Raises the MouseHover event.
Protected methodOnMouseLeave
Raises the MouseLeave event.
Protected methodOnMouseMove
Raises the MouseMove event.
Protected methodOnMouseUp
Raises the MouseUp event.
Protected methodOnMouseWheel
Raises the MouseWheel event.
Protected methodOnMove
Raises the Move event.
Protected methodOnNotifyMessage
Notifies the control of Windows messages.
Protected methodOnPaddingChanged
Raises the PaddingChanged event.
Protected methodOnPaint
Overridden.
(Overrides ControlOnPaint(PaintEventArgs).)
Protected methodOnPaintBackground
Overridden. Prevents painting the background of the control.
(Overrides ScrollableControlOnPaintBackground(PaintEventArgs).)
Protected methodOnParentBackColorChanged
Raises the BackColorChanged event when the BackColor property value of the control's container changes.
Protected methodOnParentBackgroundImageChanged
Raises the BackgroundImageChanged event when the BackgroundImage property value of the control's container changes.
Protected methodOnParentBindingContextChanged
Raises the BindingContextChanged event when the BindingContext property value of the control's container changes.
Protected methodOnParentChanged (Inherited from ContainerControl.)
Protected methodOnParentCursorChanged
Protected methodOnParentEnabledChanged
Raises the EnabledChanged event when the Enabled property value of the control's container changes.
Protected methodOnParentFontChanged
Raises the FontChanged event when the Font property value of the control's container changes.
Protected methodOnParentForeColorChanged
Raises the ForeColorChanged event when the ForeColor property value of the control's container changes.
Protected methodOnParentRightToLeftChanged
Raises the RightToLeftChanged event when the RightToLeft property value of the control's container changes.
Protected methodOnParentVisibleChanged
Raises the VisibleChanged event when the Visible property value of the control's container changes.
Protected methodOnPreviewKeyDown
Raises the PreviewKeyDown event.
Protected methodOnPrint
Raises the Paint event.
Protected methodOnPropertyChanged
Inheritors must call base method in order to notify value for Binding
Protected methodOnQueryContinueDrag
Raises the QueryContinueDrag event.
Protected methodOnRegionChanged
Raises the RegionChanged event.
Protected methodOnResize (Inherited from UserControl.)
Protected methodOnRightToLeftChanged (Inherited from ScrollableControl.)
Protected methodOnScroll
Raises the Scroll event.
Protected methodOnSizeChanged
Raises the SizeChanged event.
Protected methodOnStyleChanged
Raises the StyleChanged event.
Protected methodOnSystemColorsChanged
Raises the SystemColorsChanged event.
Protected methodOnTabIndexChanged
Raises the TabIndexChanged event.
Protected methodOnTabStopChanged
Raises the TabStopChanged event.
Protected methodOnTextChanged
Raises the TextChanged event.
Protected methodOnValidated
Raises the Validated event.
Protected methodOnValidating
Raises the Validating event.
Protected methodOnVisibleChanged (Inherited from ScrollableControl.)
Public methodPerformAutoScale
Performs scaling of the container control and its children.
Public methodPerformLayout
Forces the control to apply layout logic to all its child controls.
Public methodPerformLayout(Control, String)
Public methodPointToClient
Computes the location of the specified screen point into client coordinates.
Public methodPointToScreen
Computes the location of the specified client point into screen coordinates.
Public methodPreProcessControlMessage
Preprocesses keyboard or input messages within the message loop before they are dispatched.
Public methodPreProcessMessage
Protected methodProcessCmdKey (Inherited from ContainerControl.)
Protected methodProcessDialogChar (Inherited from ContainerControl.)
Protected methodProcessDialogKey (Inherited from ContainerControl.)
Protected methodProcessKeyEventArgs
Processes a key message and generates the appropriate control events.
Protected methodProcessKeyMessage
Processes a keyboard message.
Protected methodProcessKeyPreview
Previews a keyboard message.
Protected methodProcessMnemonic (Inherited from ContainerControl.)
Protected methodProcessTabKey
Selects the next available control and makes it the active control.
Protected methodRaiseDragEvent
Raises the appropriate drag event.
Protected methodRaiseKeyEvent
Raises the appropriate key event.
Protected methodRaiseMouseEvent
Raises the appropriate mouse event.
Protected methodRaisePaintEvent
Raises the appropriate paint event.
Protected methodRecreateHandle
Forces the re-creation of the handle for the control.
Public methodRectangleToClient
Computes the size and location of the specified screen rectangle in client coordinates.
Public methodRectangleToScreen
Computes the size and location of the specified client rectangle in screen coordinates.
Public methodRefresh
Forces the control to invalidate its client area and immediately redraw itself and any child controls.
Public methodResetBackColor
Resets the BackColor property to its default value.
Public methodResetBindings
Causes a control bound to the BindingSource to reread all the items in the list and refresh their displayed values.
Public methodResetCursor
Resets the Cursor property to its default value.
Public methodResetFont
Resets the Font property to its default value.
Public methodResetForeColor
Resets the ForeColor property to its default value.
Public methodResetImeMode
Resets the ImeMode property to its default value.
Protected methodResetMouseEventArgs
Resets the control to handle the MouseLeave event.
Public methodResetRightToLeft
Resets the RightToLeft property to its default value.
Public methodResetText
Resets the Text property to its default value.
Public methodResumeLayout
Resumes usual layout logic.
Public methodResumeLayout(Boolean)
Resumes usual layout logic, optionally forcing an immediate layout of pending layout requests.
Protected methodRtlTranslateAlignment(HorizontalAlignment)
Converts the specified HorizontalAlignment to the appropriate HorizontalAlignment to support right-to-left text.
Protected methodRtlTranslateAlignment(LeftRightAlignment)
Converts the specified LeftRightAlignment to the appropriate LeftRightAlignment to support right-to-left text.
Protected methodRtlTranslateAlignment(ContentAlignment)
Converts the specified ContentAlignment to the appropriate ContentAlignment to support right-to-left text.
Protected methodRtlTranslateContent
Protected methodRtlTranslateHorizontal
Protected methodRtlTranslateLeftRight
Public methodScale(Single) Obsolete.
Scales the control and any child controls.
Public methodScale(SizeF)
Scales the control and all child controls by the specified scaling factor.
Public methodScale(Single, Single) Obsolete.
Scales the entire control and any child controls.
Protected methodScaleControl (Inherited from ScrollableControl.)
Protected methodScaleCore (Inherited from ScrollableControl.)
Public methodScrollControlIntoView
Scrolls the specified child control into view on an auto-scroll enabled control.
Protected methodScrollToControl
Calculates the scroll offset to the specified child control.
Public methodSelect
Activates the control.
Protected methodSelect(Boolean, Boolean) (Inherited from ContainerControl.)
Public methodSelectNextControl
Activates the next control.
Public methodSendToBack
Sends the control to the back of the z-order.
Public methodSetAutoScrollMargin
Sets the size of the auto-scroll margins.
Protected methodSetAutoSizeMode
Sets a value indicating how a control will behave when its AutoSize property is enabled.
Public methodSetBounds(Int32, Int32, Int32, Int32)
Sets the bounds of the control to the specified location and size.
Public methodSetBounds(Int32, Int32, Int32, Int32, BoundsSpecified)
Sets the specified bounds of the control to the specified location and size.
Protected methodSetBoundsCore
Performs the work of setting the specified bounds of this control.
Protected methodSetClientSizeCore
Sets the size of the client area of the control.
Protected methodSetDisplayRectLocation
Positions the display window to the specified value.
Protected methodSetScrollState
Sets the specified scroll state flag.
Protected methodSetStyle
Sets a specified ControlStyles flag to either true or false.
Protected methodSetTopLevel
Sets the control as the top-level control.
Protected methodSetVisibleCore
Sets the control to the specified visible state.
Public methodShow
Displays the control to the user.
Protected methodSizeFromClientSize
Determines the size of the entire control from the height and width of its client area.
Public methodSuspendLayout
Temporarily suspends the layout logic for the control.
Public methodToString
Returns a String containing the name of the Component, if any. This method should not be overridden.
Public methodUpdate
Causes the control to redraw the invalidated regions within its client area.
Protected methodUpdateBounds
Updates the bounds of the control with the current size and location.
Protected methodUpdateBounds(Int32, Int32, Int32, Int32)
Updates the bounds of the control with the specified size and location.
Protected methodUpdateBounds(Int32, Int32, Int32, Int32, Int32, Int32)
Updates the bounds of the control with the specified size, location, and client size.
Protected methodUpdateDefaultButton
When overridden by a derived class, updates which button is the default button.
Protected methodUpdateStyles
Forces the assigned styles to be reapplied to the control.
Protected methodUpdateZOrder
Updates the control in its parent's z-order.
Public methodValidate
Verifies the value of the control losing focus by causing the Validating and Validated events to occur, in that order.
Public methodValidate(Boolean)
Verifies the value of the control that is losing focus; conditionally dependent on whether automatic validation is turned on.
Public methodValidateChildren (Inherited from UserControl.)
Public methodValidateChildren(ValidationConstraints) (Inherited from UserControl.)
Protected methodWndProc (Inherited from UserControl.)
Top
See Also
