Click or drag to resize
ExecutionStateException Properties
The ExecutionStateException type exposes the following members.
Properties
  NameDescription
Public propertyData
Gets a collection of key/value pairs that provide additional user-defined information about the exception.
(Inherited from Exception.)
Public propertyExtendedErrorInformation
Extended error information.
(Inherited from BaseException.)
Public propertyHelpLink
Gets or sets a link to the help file associated with this exception.
Public propertyHResult
An internal return code from a failing native call. Only relevant for ABB developers team.
Public propertyInnerException
Gets the Exception instance that caused the current exception.
Public propertyIsHResultValid
Check if the internal return code from a failing native call is valid. Only relevant for ABB developers team.
Public propertyMessage
Gets a message that describes the current exception.
Public propertyName
Class name
(Overrides GeneralExceptionName.)
Public propertySource
Gets or sets the name of the application or the object that causes the error.
Public propertyStackTrace
Gets a string representation of the frames on the call stack at the time the current exception was thrown.
Public propertyTargetSite
Gets the method that throws the current exception.
Top
See Also
