BaseException Class |
Namespace: ABB.Robotics
public class BaseException : ApplicationException
The BaseException type exposes the following members.
| Name | Description | |
| BaseException(Exception, String, String, String) |
Overloaded constructor.
| BaseException(Int32, String, String, String) |
| BaseException(String, String, String, String) |
| Data | Gets a collection of key/value pairs that provide additional user-defined information about the exception. (Inherited from Exception.) | |
| ExtendedErrorInformation |
Extended error information.
| HelpLink | Gets or sets a link to the help file associated with this exception. (Inherited from Exception.) | |
| HResult |
An internal return code from a failing native call. Only relevant for ABB developers team.
| InnerException | Gets the Exception instance that caused the current exception. (Inherited from Exception.) | |
| IsHResultValid |
Check if the internal return code from a failing native call is valid.
| Message |
Gets a message that describes the current exception.
(Overrides ExceptionMessage.) | |
| Name |
Represent the name of the Class, i.e. "ABB.Robotics.BaseException".
| Source | Gets or sets the name of the application or the object that causes the error. (Inherited from Exception.) | |
| StackTrace | Gets a string representation of the frames on the call stack at the time the current exception was thrown. (Inherited from Exception.) | |
| TargetSite | Gets the method that throws the current exception. (Inherited from Exception.) |
| Finalize | Allows an object to try to free resources and perform other cleanup operations before it is reclaimed by garbage collection. (Inherited from Object.) | |
| GetBaseException | When overridden in a derived class, returns the Exception that is the root cause of one or more subsequent exceptions. (Inherited from Exception.) | |
| GetObjectData | When overridden in a derived class, sets the SerializationInfo with information about the exception. (Inherited from Exception.) | |
| GetType | Gets the runtime type of the current instance. (Inherited from Exception.) | |
| ToString |
Convert exception to string
(Overrides ExceptionToString.) |
