ModPosExceptionProblemReason Enumeration |
The reason for a modify position problem.
Namespace:
ABB.Robotics
Assembly:
ABB.Robotics (in ABB.Robotics.dll) Version: 6.5.129.0
Syntaxpublic enum ProblemReason
Members|
| Member name | Value | Description |
| IllegalExecutionState | 0 |
Operation is illegal in current execution state.
| WrongActiveTool | 1 |
Wrong active tool.
| WrongActiveWorkobject | 2 |
Wrong active workobject.
| MechanicalUnitNotWithinLimit | 3 |
The position of the mechanical unit is not within limits.
| ObjectNotModossible | 4 |
Object is not modpossible.
| IllegalSourcePosition | 5 |
The given source position is illegal for the operation.
| NoSuchSymbol | 6 |
RAPID symbol was not found.
| MechanicalUnitDeactivated | 7 |
At least one axis is deactivated since last modpos.
| NoTCPRobotActive | 8 |
No TCP robot activated.
See Also
