FlexPendant Developer Support
FlexPendant Development
References
ListViewSubItemCollection Class
ListViewSubItemCollection Methods
Add Method
Contains Method
IndexOf Method
Insert Method
OnClear Method
OnClearComplete Method
OnInsertComplete Method
OnRemoveComplete Method
Remove Method
Contains Method
Determines if the specified
ListViewSubItem
is a member of the collection.
Namespace:
Assembly:
Syntax
C#
Copy
public
virtual
bool
Contains
ListViewSubItem
item
Parameters
item
Type:
ListViewSubItem
The
ListViewSubItem
to locate in the collection.
Return Value
Type:
Boolean
true
if the
ListViewSubItem
is a member of the collection; otherwise,
false
See Also
Reference
ABB.Robotics.Tps.Windows.Forms Namespace
FlexPendant Developer Center | This content is licensed. For details and restrictions, see the
Content License
