FlexPendant Developer Support
FlexPendant Development
References
ListViewSubItemCollection Class
ListViewSubItemCollection Methods
Add Method
Contains Method
IndexOf Method
Insert Method
OnClear Method
OnClearComplete Method
OnInsertComplete Method
OnRemoveComplete Method
Remove Method
IndexOf Method
Returns the index within the collection of the specified item.
Namespace:
Assembly:
Syntax
C#
Copy
public
virtual
int
IndexOf
ListViewSubItem
item
Parameters
item
Type:
ListViewSubItem
The
ListViewSubItem
to locate in the collection.
Return Value
Type:
Int32
The zero-based index of the item found in the collection; otherwise, -1.
See Also
Reference
ABB.Robotics.Tps.Windows.Forms Namespace
FlexPendant Developer Center | This content is licensed. For details and restrictions, see the
Content License
