ArrayData Methods |
The ArrayData type exposes the following members.
| Name | Description | |
| FillFromString |
Fills the array with a valid rapid string representation.
| Finalize | Allows an object to try to free resources and perform other cleanup operations before it is reclaimed by garbage collection. (Inherited from Object.) | |
| GetEnumerator |
Gets an IEnumerator object for the array
| GetLength |
Gets the length of the specified dimension.
Zero based index.
| ToString |
Returns the string representation of the rapid data array.
(Overrides ObjectToString.) |
