ListViewItemHeigth Property |
Gets or sets the height of an item in the
ListView.
Namespace:
Assembly:
Syntaxpublic int ItemHeigth { get; set; }Property Value
Type:
Int32The height, in pixels, of an item in the control. The default value is
-1.
Remarks
If this property has a value of -1, the control will set a default row height suitable for the touch screen.
NOTE: Use default value of ItemHeigth in order to follow the UI guidelines. This property is used only for specific cases.
See Also
