ListViewSelectionEnabledOverScrollbuttons Property |
Gets or sets a value indicating whether a mouse event must select an item or scroll the list inside scroll regions.
Namespace:
Assembly:
Syntaxpublic bool SelectionEnabledOverScrollbuttons { get; set; }Property Value
Type:
Booleantrue to allow to select the item;
false to scroll the list. The default is
false.
RemarksNOTE:Either is the listview controls does not have scroll bars, this property
is used. For example, if there are no scroll bars and the mouse down was pressed in the
scroll region, no selection will be perfomed if this property is set to false.
See Also
