ITpsViewLaunchServicesCloseView Method |
Closes a view which has been launched with the method LaunchView.
Namespace:
ABB.Robotics.Tps.Taf
Assembly:
ABB.Robotics.Tps.Taf (in ABB.Robotics.Tps.Taf.dll) Version: 6.5.129.0
Syntaxvoid CloseView(
Object cookie
Parameters
- cookie
- Type: SystemObject
The out parameter from the method LaunchView.
RemarksIf the cookie is not up-to-date the method will just return without any action, else
the view is closed and removed from the task bar.
Examples
In this example the Backup and Restore view is launched and then closed.
if (_iTpsSite.LaunchView(FpStandardView.BackUpRestore, null, false, out _cookieB) != true)
_iTpsSite.CloseView(_cookieB);
See Also
