Click or drag to resize
ComboBoxObjectCollectionContains Method
Determines if the specified itemis a member of the collection.
Namespace:  ABB.Robotics.Tps.Windows.Forms
Assembly:  ABB.Robotics.Tps.Windows.Forms (in ABB.Robotics.Tps.Windows.Forms.dll) Version: 6.5.129.0
Syntax
C#
public virtual bool Contains(
	Object item
Parameters
item
Type: SystemObject
The item to locate in the collection.
Return Value
Type: Boolean
true if the item is a member of the collection; otherwise, false.
See Also
