Click or drag to resize
ObjectCollection Methods
The ComboBoxObjectCollection type exposes the following members.
Methods
  NameDescription
Public methodAdd
Adds an existing item object to the collection.
Public methodClear
Removes all objects from the CollectionBase instance. This method cannot be overridden.
(Inherited from CollectionBase.)
Public methodContains
Determines if the specified itemis a member of the collection.
Public methodEquals
Determines whether the specified Object is equal to the current Object.
(Inherited from Object.)
Protected methodFinalize
Allows an object to try to free resources and perform other cleanup operations before it is reclaimed by garbage collection.
Public methodGetEnumerator
Returns an enumerator that iterates through the CollectionBase instance.
Public methodGetHashCode
Serves as a hash function for a particular type.
Public methodGetType
Gets the type of the current instance.
Public methodIndexOf
Returns the index within the collection of the specified item.
Public methodInsert
Inserts an existing item into the collection at the specified index.
Protected methodMemberwiseClone
Creates a shallow copy of the current Object.
Protected methodOnClear
Overridden. Stores a copy of the item to remove their connections.
(Overrides CollectionBaseOnClear.)
Protected methodOnClearComplete
Overridden. Removes the connection of the item stored.
(Overrides CollectionBaseOnClearComplete.)
Protected methodOnInsert
Performs additional custom processes before inserting a new element into the CollectionBase instance.
Protected methodOnInsertComplete
Overridden. Adds the connection of the item.
(Overrides CollectionBaseOnInsertComplete(Int32, Object).)
Protected methodOnRemove
Performs additional custom processes when removing an element from the CollectionBase instance.
Protected methodOnRemoveComplete
Overridden. Removes the connection of the item.
(Overrides CollectionBaseOnRemoveComplete(Int32, Object).)
Protected methodOnSet
Performs additional custom processes before setting a value in the CollectionBase instance.
Protected methodOnSetComplete
Performs additional custom processes after setting a value in the CollectionBase instance.
Protected methodOnValidate
Performs additional custom processes when validating a value.
Public methodRemove
Removes the specified item from the collection.
Public methodRemoveAt
Removes the element at the specified index of the CollectionBase instance. This method is not overridable.
Public methodToString
Returns a string that represents the current object.
Top
See Also
