GTPUMasterDialogCancelItemEnabled Property |
Gets or sets a value indicating whether the control will have an Cancel item in the command bar.
Namespace:
Assembly:
ABB.Robotics.GTPU.Windows.Forms (in ABB.Robotics.GTPU.Windows.Forms.dll) Version: 6.5.129.0
Syntaxprotected bool CancelItemEnabled { get; set; }Property Value
Type:
Booleantrue if the control will have a Cancel item; otherwise
false. the default value is
false.
Remarks
The Cancel Item will be shown if this property is set to
true and the
Menu property is not null. The Cancel item is located in the right side of the command bar following the GTPU guidelines.
The text of the Cancel item could be set by the property
CancelItem. The default text is
Ok and its localized.
In order to be notified whenever the Cancel item is pressed, inheritors must override the method
ActionItem_Click(Object, EventArgs).
See Also
